Fuel system
Fuel system
Category: Accessories
Price: $650
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V, 67-92 Chevrolet Camaro, 67-92 Pontiac Firebird, Front wheel drive vehicles
Location (State): MI
Item Condition: Brand New
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6, LT1/LT4, Small Block, Big Block
LS Engine?: Fits LS Engine
Cost around $1000.00 new
Combo Racing Fuel Pump PE 4450
Jobber: $569.00
•460+ Gallons per hour
•Adjustable up to 43 P.S.I. (approx. 35 PSI max @ 12 Volts; approx. 43 PSI max @ 16 Volts)
•External -8 bypass valve (adjustable)
•Cleanable filter
•Alcohol compatible
•Works with 12 or 16 volts
•7 Vane impeller
•-12 AN boss O-ring inlet & outlet ports
•Continuous duty
•2 Year Parts & Labor Warranty
From Pro Stock to Pro Street. This is the top of the line, maximum output pump for applications up to 2000 Horsepower. It can easily handle twin Dominator® carbs and multiple nitrous systems...All from one pump! Although referred to as a 'racing fuel pump', this pump as well as all of our others, is perfectly at home on high performance street cars. The custom built, heavy duty 3" diameter motor is made specifically for continuous duty. The body is C.N.C. machined from 6061-T6 billet aluminum and hard anodized for exceptional wear characteristics. The 7 vane impeller promotes excellent priming and smooth flow. It's cleanable filter element is a synthetic mesh screen which flows 4000 GPH. The pump is shown here in the traditional colors of blue/gold. Optional color combinations are: purple/gold and black/gold. Special color combinations are available for a nominal charge. Matching HI-FLO fittings available in blue, black, gold and purple.
