FAST-FLASH™ Power Programmer - 98-05' GM Gasoline Engines
Category: Engine - Intake/Fuel
Price: $80
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): GA
Item Condition: Used
LS Engine?: Fits LS Engine
•98-00 GM Gas Trucks w/ 4.3, 5.0, 5.7, 7.4 - Auto/5 Speed Manual Transmission - CK1500, 2500, 3500/S10
•99-05 GM Gas Trucks/Hummers/Escalades/Denali w/ 4.8, 5.3, 6.0, 8.1 - Auto/5 Speed Manual Transmission
•99-04 GM Corvette, Camaro, Firebird, 04 GTO - 5.7 LS1 Auto/6 Speed Manual Transmission
FAST-FLASH™ Power Programmers give your vehicle a 15 minute tune-up that unlocks hidden performance potential, yielding maximum horsepower and torque. The process is simple – just plug the programmer into your vehicle’s under-dash ODBII port, and answer a few questions. Select from three distinct modes (performance, towing or economy), and FAST-FLASH™ automatically reprograms your vehicle’s computer for idle quality and optimized air/fuel ratios. It also re-calibrates the ignition timing, transmission shift points and the speedometer for gear and tire changes
• Select from performance, towing or economy mode
• Optimize engine parameters for performance camshafts
• Modify/remove stock speed limiter setting
• Calibrate fuel octane level for various fuels
• Adjust the spark curve for the fine tuning of ignition timing
• Read live streaming engine data
• Modify air/fuel ratio at wide-open throttle
• Change engine idle speed and cooling fan activation temperature
• Check and clear diagnostic trouble codes
• Adjust the transmission shift points & firmness
that is what's on their website. $80+ shipping call or text 706-331-3221
