Notices
Parts Classifieds This an archive of the older parts classifieds, please create a new listing in our Marketplace.
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Huron Speed V2 T6 Turbo Kit Complete w/ S475, WG's, BOV, Oil lines, etc
Old 03-16-2015, 06:05 PM
LS1Tech Sponsor
Superman09's Avatar
Default Huron Speed V2 T6 Turbo Kit Complete w/ S475, WG's, BOV, Oil lines, etc
Category: Accessories
Price: $4895
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): MI
Item Condition: Brand New
Engine: LS1/LS6
LS Engine?: Fits LS Engine
Up for sale is a Brand New Huron Speed V2 T6 Turbo Kit.
We have this unit sitting on the shelf ready to go! No wait time, order and ship!
Our standard V2 T6 kit complete w/ Race-Cover S475 Turbo, Turbosmart Hyper-Gate 45 Wastegates, XS-Power BOV, Oil Feed and Drain Line Kit, and a Turbo Blanket!
Includes:
-Our new V2 Stainless Steel, Vbanded, extra thick .120 wall Manifolds that retain the OEM Alternator location
-2.25” extra thick .120 wall Stainless Crossover with divided T6 flange, True divided crossover set-up with twin 44mm WG flanges (one per bank) and bungs for primary O2 sensors. Added joint to allow for easier installation. All piping stays ABOVE the oem sway bar as well!
-5" - 4" Stainless 2-piece downpipe routed out the front bumper with a wideband O2 bung and plug. 2-piece connection with a v-band to allow easy installation of the exiting, fully polished tip.
-Turbo Support bracket that also doubles as the turbo oil drain for easy hook up.
-4" Thick Core intercooler with direct bolt on brackets
-Fully Polished 3” and 3.5" Cold side piping from Turbo to Intercooler and Intercooler to Throttle Body with 50mm BOV flange.
-All necessary couplers and clamps, only straight couplers are used in this kit to avoid any worries of blowing out elbow couplers! Entire hotside consists of all v-band connections
-Stainless Steel Hex Head Bolt/Hardware Kit included!
-BW S475 Turbocharger, 96mm turbine wheel, 1.32 a/r, Race Cover from Bullseye
-(2) Turbosmart Hyper-Gate 45 Wastegates
-XS-Power 50mm BOV
-HSP T6 Oil Feed and Drain Line Kit included!
-T6 Turbo Blanket included!
-Shipping Included
*Kit requires: Stood up radiator (dual pass recommended) with coolant hoses and fans to clear piping/turbo. A/C removal. Relocation of battery and coolant overflow tank to fit the charge pipe to throttle body *If retaining ABS, requires minor lowering of ABS block. Some turbos may require a small enlargement of it's mounting holes ( typically only 2 if any as manufacturers spacing tends to vary we have noticed). Lower Radiator Hose outlet may require modification depending on your specific placement of the radiatior.
*Kit RETAINS: OEM Alternator location, OEM Front Sway bar, OEM Power steering, *ABS, and OEM or any aftermarket K-member!
$4895 SHIPPED
Picture below shows all components you will receive PLUS the Turbo, Wastegates, BOV, Oil Line kit and the Turbo Blanket!
Photos shown below are intended so you can see the kit installed.
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 03-17-2015, 01:14 PM
LS1Tech Sponsor
Superman09's Avatar
BumP!
__________________
Quick Reply: Huron Speed V2 T6 Turbo Kit Complete w/ S475, WG's, BOV, Oil lines, etc
