Holley EFI Dominator, 370 short block, KB Racing Turbo kit
Category: Engine - Complete Motors
Price: $1
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): TX
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
First thing for sale is a Holley Dominator EFI set up. I will only sell this complete and will not part it out. Has everything needed to run any lsx motor on boost and nitrous. Comes with boost control valves, nitrous solenoids and 5.7" touch screen. Please see below for a detailed list of whats included.
Items included
Dominator ECU Part# 554-114 $1970
J1 A/B harness Part# 558-400 $68
J2A harness Part# 558-401 $133
LS1 harness Part# 558-102 $364
LSX injector harness Part# 558-102 $95
4l60/80e harness Part# 558-405 $162
(4) Universal gauges Part# 553-100 $436
(2) NTK wideband Part# 554-100 $466
(2) 100psi sensors Part# 554-102 $228
Holley 3 bar map sensor Part# 554-107 $87
(2) High current nitrous solenoid PART# 554-111 $162
(2) 3 port boost control valve Part# 557-200 $196
Main power harness Part# 558-308 $57
5.7" LCD touch Screen Part# 553-103 $700
Total in everything mentioned above was $5124 new from holley, I will take $4000 shipped. Includes all insurance for $4k
Forged 370ci short block
This short block was built and assembled by Chris at The School of Automotive Machinist here in Houston TX. The short block is currently being taken to Chris to have him inspect it before it goes to its new home. Made 800hp+ to the wheels on 14psi. It never saw anything greater then 14psi since new. 2000 miles on it.
Specs
Wiseco flat top pistons with upgraded wrist pins
Molnar turbo H-beam rods
Total seal rings
King Bearings
58X crank I also have a lingenfelter box to covert from 58 to 24
$2600 + Shipping
KB Racing front mount turbo hot and cold side. hot side will fit 88-2006. the cold side will bolt onk 88-98 and will work on 99-06 with slight modifications.
If you are purchasing the hot side for a 99-06 I will add a 99-06 Down pipe, if you are purchasing for a 88-98 I will send the down pipe for your year model.
This kit will also come with a TBSS drivers manifold.
stainless steel braided lines,
5/8 drain
All fittings, hoses and clamps
BOV 50mm
Waste gate 46mm precision
Borgwarner s/480 80/92 billet turbo
Billet V3 80mm by Jose/DrTurbo
Standard 4" outlet compressor housing
92mm inducer, 83mm exducer turbine
1.0 T4 turbine housing
$4200 shipped.
On to the pics!!
Also has a ported exhaust housing.
