Notices
KLX300R for a Moser 12 bolt Rearend w/ Truetrac and built 4L60E
Old 04-04-2007, 04:02 PM
sbusby's Avatar
Default KLX300R for a Moser 12 bolt Rearend w/ Truetrac and built 4L60E
I'm looking for a built 4L60E and Moser 12 bolt rearend for trade of a band new Kawasaki KLX 300R Dirt bike...
The bike is still new at the dealership and never been ridden.
OR
A new Ninja 500R same condition, new at the dealership. I can even get the color of the bike you want...
KLX 300R Specs
Engine Four-stroke, DOHC, four-valve single
Displacement 292cc
Bore x stroke 78.0 x 61.2mm
Compression ratio 11.0:1
Cooling Liquid
Carburetion Keihin CVK34
Ignition Digital CDI
Transmission Six-speed, manual clutch
Final drive Chain
Frame High-tensile steel, perimeter design
Rake / trail 26.5 degrees / 4.2 in.
Front suspension / wheel travel 43mm inverted cartridge fork with 20-way compression damping / 11.2 in.
Rear suspension / wheel travel UNI-TRAK® single shock system with 20-way compression damping and 18-way rebound damping / 11.0 in.
Front tire 80/100x21
Rear tire 100/100x18
Front brake / rear brake Hydraulic disc / Disc
Overall length 83.3 in.
Overall width 35.8 in.
Overall height 48.0 in.
Seat height 36.4 in.
Wheelbase 56.5 in.
Ground clearance 12.6 in.
Fuel capacity 2.6 gal.
Dry weight 233.7 lbs.
Color Lime Green / Black
Good Times™ Protection Plan 12, 24 or 36 months
Warranty 6 Months
