99 LS1 engine/harness/pcm/radiator/kmember
I am looking to do a ls1 swap to our 99 firebird that currently has the 3.8 in it. We would ideally like to get all the components from a 99 ls1 car as that would make for direct swaps with wiring and such.
So yea we need these parts from a 99 vehicle:
Engine
4l60e trans
kmember
wiring harness
pcm
radiator
pedal assembly
Engine
4l60e trans
kmember
wiring harness
pcm
radiator
pedal assembly
Just posted this stuff in the 'Parts For Sale' section if you're interested.
https://ls1tech.com/forums/lsx-parts-sale/748870-nib-spohn-32mm-front-sway-bar-stb.html
i have a 98, with 2002 5.3 heads. Motor is apart and needs put back together. Cylinders were cleaned up and was then tanked. Have all new bearings rod-main-cam "std", rings "std", all gaskets from gm, melling oil pump, new timing chain. 1500.00 shipped. also have the truck intake, fuel rails, injectors, t-body and maf that comes with it.....
