My gains with LS1 Edit
I gained over 17 hp and 13 ft lbs of torque at the wheels. Almost no timing was put in the car, a degree or 2. What a difference in the before and after dyno sheets. For anyone thinking about it, do it. It's worth it
Re: My gains with LS1 Edit
Did you go to the dyno and tune it yourself? Makes me want to go because I know there is power to be gained in my car from tuning.
Jordan
Jordan
Actually, when I pulled your program out to begin tuning, it didn't look like the HPP3 had done anything. The only thing that the HPP3 appeared to have changed was your rev limiter. Other than that all of your timing and a/f was stock.
I thought you had just used the HPP3 to do your rev limiter???
Either way, I'm glad your happy with the result.
Good Luck
Good Luck
Kevin, I didn't get to meet you when I picked up my car. You guy's looked real busy. I asked who did the work and Guy pointed into the shop and said " Kevin did ". There were about 7 people walking around inside. I'm doing headers/cam next. Any suggestions?
