ignition coil 7 control circuit?
Well, I unplugged my battery and took out the pcm, cleaned everything and checked everything over. Put it back in and rode around for a half hour scanning for codes with hp tuners and it never came back. I hope it's gone but I really didn't see anything out of ordinary. I'll cross my fingers.
i had the p0357 pop up off and on for a year then the p0358 showed up recently. I would clear them and no problems. Then one day it just went to **** and started missing. Unplugged battery, retuned, you name it. I think the PCM just got toasted and the associated drivers are weak.
So I think its gone, I swapped the entire coil rack from side to side and it seems gone. I think my problem is my drivers side ground wire on the back of the head is very short pulling on the harness quite hard, I am going to make it a little longer, it broke when doing heads/cam and I just put a new connector on it. It was pulling very hard on the coil pack harness.
i had a bad coil pack harness some how on my car. dont now how it happened. i swicth out the old one and it went away. crazy things happen
