PLx to Hptuners Question
I have installed My PLX gauge and DM100 and I need to know how to make it read into Hptuners.
Trick Is I do not have HPtuners. So when I go to get my car tuned I want the individuals using hp tuners, to not have to do much to make it work. Can I just hook it up through my EGr and he can Log the egr for the wideband?
Any help is appreciated!
It was easy to hook up. HP Tuners has an interface cable from the laptop to the vcm. You will see 8 pins for auxilliary inputs.
Take the 2 wires from the PLX sensor module that can go to the AFR gauge. Hook plus up to pin 1 and minus up to pin 5.
There was one more step, too. In the VCM scanner program you have to tell it you have a PLX wideband hooked up. I don't know exactly where. Tuner should be able to find that pretty easy in the help file.
