2002 Camaro SS - Need help with Predator shift options
Old 10-25-2008, 10:16 AM
SSDetroit's Avatar
Default 2002 Camaro SS - Need help with Predator shift options
I have the Predator U7198 with 2.13 revision. I am a bit confused on how to get my camaro to shift harder in the 1-2 shift. I used a predator a couple years back on my stock 2000 Camaro SS, it would chirp the tires on every 1-2 shift. Whatever revision I had at that time, seemed to have different options when modifying the tune. If I recall, there were far fewer options and I think there was a shift firmness option that gave me nice hard shifts.
Now, I have the following options:
Shift time - Upshift MPH - downshift mph - upshift rpm - WOT pressure - part throttle shift - and of course TM.
I have read very little on how I can adjust these parameters in tandem to get the results I want. I assume I turn all three Torque Management options off, after that I have no idea. Can anyone point me in the right direction or to information that can help me better understand these options?
Also, I do have a Yank SS 3600 convertor on my car, and soon to get some M/T ET streets and a small dose of Nitrous.
Old 10-25-2008, 10:20 AM
IllusionalTA's Avatar
up the wot pressure and reduce the shift time
Old 10-25-2008, 11:05 AM
SSDetroit's Avatar
Any idea on how firm I should adjust the WOT pressure to?
Old 10-25-2008, 11:40 AM
That's upto you play with it till u find what you like
Old 01-15-2009, 10:51 PM
zrultima's Avatar
whg difference does it make if you puit for example shift time -15 sec
Old 01-16-2009, 09:39 AM
LS1Tech Sponsor
Mike@Diablosport's Avatar
Shift time is set to the max speed in the tunes already, so changing it makes no difference unless modifying the factory tune.
Thanks
Mike
