1bar map on a 3 bar tune....experts
Old 10-29-2008, 08:32 PM
cablebandit's Avatar
Default 1bar map on a 3 bar tune....experts
Trying to help someone out. IF they are tuned for a 3 bar sensor, what would happen if they installed a 2bar sensor but didnt change the scaler. He turned the FP way down to get it to run. To me this means he has a 1bar tune...not a 3 bar. He is for SURE using a 2 bar sensor now.
Old 10-29-2008, 08:57 PM
Frost's Avatar
it will get progressively fatter as he moves away from idle
Old 10-29-2008, 09:38 PM
that sounds backwards to me.
Old 10-29-2008, 10:51 PM
Frost's Avatar
think of it like this; The VE value that used to occupy X RPMs and 165 kPa (roughly VE and sensor output V center) will now occupy the same X RPMs and 115 kPa (again, roughly VE and sensor output center). Basically the fueling he used to be given at 9ish PSI will now be delivered at about 2ish PSI. Of course the same applies in vacuum.
Old 10-29-2008, 11:37 PM
yeah thats what i dont understand.......so it would be too rich in vacuum as well? (3bar tune/2 bar sensor)
Old 10-29-2008, 11:46 PM
Frost's Avatar
that's right.
