Which MAF can i use?
Old 11-09-2008, 11:13 PM
spdrcr7882's Avatar
Default Which MAF can i use?
I have a 99 camaro with a 5.3L that is turbo'd. I had a 85 mm MAF in my ic piping right before the throttle body. The other day i blew the MAF in half when i was making boost. I wanna get another, but i was told that a 75 mm maf would be better, which vehicles use a 75mm maf that i can use on my car, besides the obvious f-bodies? I wanna pick one up from the junk yard, and this could make it much easier, and cheaper to find one
Thanks
Justin
Old 11-12-2008, 08:02 PM
blackls1ta00's Avatar
75 is stock maf
Old 12-02-2008, 02:50 PM
spdrcr7882's Avatar
I went to a junk yard and found a 75mm maf from a 96 tahoe and it showed in their computer that this is the same as a 75 mm maf for a 99 camaro, do any know if this is true?
Justin
Old 12-11-2008, 12:03 PM
spdrcr7882's Avatar
The 3" maf from the tahoe worked without issue once installed.
Justin
