Crank relearn procedure?
Restricted User
Re: Crank relearn procedure?
This doc explains the ckp relearn
http://www.seattleautomotive.com/ckpdoc.htm
You can do it with EFILive if you have the Pro
verison.
A dealer with a Tech2 can also do it.
It only takes about 30 seconds.
verison.
i think u have to have a EASE scanner or somethign like that and tell the PCM to crank relearn
For CKS relearn you Just click on command while car/truck is parked and engine running above 4800 RPMs
verison.
verison.
Restricted User
This is what you call TOOTH ERROR LEARN, right?
EFILive V6 calls it crank position sensor relearn.
I suggest using EFILive V6 (free upgrade) instead of V5 as EFILive V6 will "walk you through" the relearn procedure with on screen feedback and instructions
Regards
Paul
