pcm test
pcm test
Is there any way to do a diagnostic on the pcm to make sure all circuts are good? I'm getting data at th port, but am hunting down a bad ground and would like to confirm it's not the pcm having a bad/burt circut.
LS1TECH Sponsor
Re: pcm test
Well I wish I could help further. I do not know of any diagnostics other than the DTC's that would indicate that. P0601-606 would be PCM probs. but that sounds highly unlikely that the PCM would be at fault. Does the car crank and run or what is the problem exactly? Have you put it on a scanner? That would be your best bet. hope this helps.
Jeremy formato
Jeremy formato
Re: pcm test
Cranks but doesn't fire. Autotap shows everything, but during cranking the voltage drops away to nothing. It's a swap so the wireing is sketchy. We have voltage/continuity all the way to the coils/injectors bu it's not fireing. Only codes are for evap. I'll try another pcm to confirm, even if the vats are wrong if it's the pcm it should fire momentarily even with a diferent pcm if that's it. Could also be a ground/short elsewhere.
Thanks for the input
