what is involved in swapping a 1995 PCM into a 1996?
You can do it one of two ways.
A. Get a 95 PCM and a 95 Knock sensor and your good to go.
B. Get a 95 PCM and solder in a 3.9K Ohm resister. This way you can keep the 96 Knock sensor and have the option of switching back to the 96 PCM if you need to or if you ever fry the 95 during programing.
Link to how its done. Internal PCM Resistor Mod: OBDII to OBDI Conversion Go down to post 11, it shows a good pic of how its done.
