I have the following codes, can anyone help?
A little background is I have H/c just installed, when i was doing pulling the intake manifold i pulled out the map wires, I tried to fix them but I suppose I did a poor job and it wasnt working/ reading weird readings (on the dyno with hptuners) And when we disconnected it and plugged it into a spare MAP that was just laying on the intakemani it got even weirder readings that started messing with the tps. I was at newtech performance in hayward if that matters at all, but he was telling me its most likely the wiring messing with things. What should I do? I already tried refixing the wiring but I dont know If i am getting the correct voltage or what not? Can someone help me?
Well i fixed it, and i'll explain how for anyone else that runs across this problem
p0200 - my injector plug on number 5 wasnt pressed down all the way
p0305 - injector plug pressed down fixed this also
p1635 - 5-volt reference circuit (1 orA) From searching this is either the TPS, MAP, or the OIL pressure circuit, its something in the wiring, for me it was the MAP, when i pulled the manifold out i pulled out one of the pins/broke a wire, so I had to put new pins in and connect it to the old wires.
Im posting this so it'll help someone in the future, if its helpful please bump it!
