PE, whats agood fuel enrichment
Old 11-25-2008, 10:34 AM
zrater's Avatar
Default PE, whats agood fuel enrichment
table for a stock 02 z. thanks
Old 11-25-2008, 11:35 AM
WeathermanShawn's Avatar
Most will start PE Enrichment at ~13.4 AFR/2000rpm and richen it to 12.5-12.8 at peak TQ (~4800).
A few will then lean it out slightly from peak TQ-peak HP..I.E. 12.8-13.0 from 4800-6400rpms.
Many methods. Some just block out a single AFR for all rpm's.
In any case, I assume you have a wideband, and can monitor knock retard.
A dyno would let you tweak your curve quite easily.
Hope that helps.
..WeathermanShawn..
Old 11-25-2008, 11:42 AM
zrater's Avatar
thanks, im just running lid and cutout, and wondering were would be best pe,
got lm1 but shes pretty fat, like 1.30 from 3000 up i think , all other fuel
adders are off. thanks
Old 11-25-2008, 12:11 PM
Thats a pretty rich PE. If you still have your Catalytic Converter protection on, that will override PE in sustained WOT.
It can be disabled. That may explain your current PE AFR's.
..WeathermanShawn..
Old 11-25-2008, 04:09 PM
zrater's Avatar
yes the cat over ride temp is set real high and i think off on top of it,
and the pe is set 1.30 from 3000 up in the file i down loaded. i thought
that was kinda fat 2, im wondering what stock setting is. thanks...
ha, i see your from denver, my sister lives in brighton...
Old 11-25-2008, 04:17 PM
SLP4CamaroSS's Avatar
Labels 0 400 800 1200 1600 2000 2400 2800 3200 3600 4000 4400 4800 5200 5600 6000 6400 6800 7200
EQ Ratio 1.17480 1.17480 1.17480 1.17480 1.17480 1.17480 1.17480 1.17480 1.17480 1.16602 1.15723 1.14844 1.14844
1.14844 1.14844 1.14844 1.14844 1.14844 1.14844
12.51276813 12.51276813 12.51276813 12.51276813 12.51276813 12.51276813 12.51276813 12.51276813 12.51276813 12.60698787 12.70274708 12.79997214 12.79997214 12.79997214 12.79997214 12.79997214 12.79997214 12.79997214 12.79997214
thats what i usual do 12.5-12.8 gradually
Old 11-25-2008, 04:21 PM
zrater's Avatar
would that work good on a stock, only lid and cutout..thanks
Old 11-26-2008, 12:32 AM
Yes, Brighton, Colorado just up the street.
Small world. I see SLP4CamaroSS is from Lawton, OK. Spent time just down the road at Altus AFB, Ok., back in the day.
I am sure he will confirm that that EQ/AFR ratio (12.5-12.8) is a nice safe AFR ratio for WOT. Even adding a lid and cutout will add additional airflow to the engine. More air, more fuel.
Others can comment, but I believe the HP difference from a AFR of 12.5-13.0 is probably no greater than 3-5%. Thats a highly generalized statement, but staying slightly rich may be a little safer for your engine..don't want detonation.
Try it out. You should notice the engine will be a a little sharper and responsive, by safely and carefully leaning it out.
Let us know how it works out.
..WeathermanShawn..
Old 11-26-2008, 01:55 PM
zrater's Avatar
thanks dude, trying to get straight again...
Old 11-26-2008, 02:46 PM
Frost's Avatar
You don't tune PE. You set it to desired and tune the MAF/VE to get your actual AFR to match what is desired.
Old 11-26-2008, 03:26 PM
1.8t's Avatar
^ I think they are referring to tuning the PE after they have already tuned the VE/MAF tables for appropriate airflow for a constant PE.
Old 11-26-2008, 04:55 PM
Frost's Avatar
just making sure that we are on the same page
Old 11-27-2008, 05:19 AM
ringram's Avatar
Leaner is usually quite good, like 13.x BUT you might not be able to get your spark up to optimal MBT, so adding fuel can let you put more optimal timing in.
Best way to check all this out is on the dyno.
Having said that most go for 13:1 as a general rule NA.
Old 11-29-2008, 05:06 PM
zrater's Avatar
well i went and made about 4 pulls and it seems to be awefully lean
according to the lm1, i set pe at 1.1800 across the board and
comes up dam lean not shure if the table that slp wrote was
alittle to lean for my car or what but i think somthing not right.
any body want to show a good pe table for a stock 02 with
cut out and lid.. thanks
Old 11-30-2008, 09:39 AM
Well, here is what I am running now:
RPM PE
2000 13.8
2400 13.5
2800 13.2
3200 13.0
3600 12.8
4000 12.8
4400 12.7
4800 12.7
5200 12.7
5600 12.8
6000 12.9
6400 13.0
6400+ 13.0
This is a little aggressive PE curve. I might recommend runner .2 - .3 richer for safety.
As to why you are running AFR's leaner than commanded could either be mechanical (injectors running out of fuel), or in your MAF calibration technique.
Not knowing exactly how you have your tune set-up, I would either contact a professional tuner, or post your tune and logs on this board and see where your problem lies.
I do not know how lean you are, but the cost of a new engine is not worth it.
..WeathermanShawn..
Old 11-30-2008, 11:38 AM
zrater's Avatar
well i forgot to mention im behind the cat with my wide band were the
pipe comes together so it maby looks lean. tuners have told me that behind
the cat is ok as long as your at wot, just is slightly leaner looking, ill trying post up some w/b af sheets from lm-1. thanks. just got snow last night, done till things dry up .. anyways hitting 2 gear the tires now chirp, but seems lean..
