What do i need to know before I tune a 98??
Old 12-03-2008, 12:52 AM
Magnet's Avatar
Default What do i need to know before I tune a 98??
I have tuned several 02's and a 01, but I haven't touched a 98 yet.. what do i need to know before I do it? Is it just plug and play as usual? I have Hptuners by the way..
Old 12-03-2008, 08:09 AM
slow's Avatar
Only flash the file you read out of the vehicle back into it, and you should be fine.
Ryan
Old 12-03-2008, 10:04 AM
Magnet's Avatar
ok...thats good to know. How about when connecting? I know the 98s are differet in somoe aspects.. do i need to do anything before i start tuning it?
Old 12-03-2008, 02:44 PM
5_02ls1's Avatar
i have a 98 and hp tuners ive also tuned a newer pcm the os is really the only difference...just plug and tune as normal....
Old 12-03-2008, 07:27 PM
GMTECH4's Avatar
the 98's have a back-up ve table and when performing the auto ve process you have to perform the corrections to the back-up table and then to the main ve table.
Old 12-03-2008, 07:40 PM
Frost's Avatar
the 99s and 00s have the secondary VE table in OE form also...
Old 12-03-2008, 09:59 PM
LS1TECH Sponsor
foff667's Avatar
Ryan
This is the most important thing, all of the other stuff is trivial IMO. Just make sure you are only flashing the file you originally read from the vehicle and you'll be fine.
Old 12-07-2008, 08:06 AM
SS2win's Avatar
Just curious, what the difference in 98's that you have to flash the original OS?
Old 12-07-2008, 08:55 AM
slow's Avatar
1998 pcms use a non segmented binary, so if you flash a calibration section from 1 os into a different OS, you will end up with a checksum issue.
On 1998 pcms if you throw a checksum code once, the pcm sets a permanant fault, and it will not provide fuel to the engine, even after reflashing a good file back into the processor.
On the 99+ pcms it is easy to identify the OS and make sure the calibration section matches, so switching files is not a big deal, they also do not set the permanant fault, making the processor a paperweight. (like the 98's)
I will assume this is why HPT says to only use the original file.
Ryan
