got question about ignition module connector.
can the ignition module connector be replaced by splicing the wires or do I need to replace the whole engine wiring harness?
I have a 98 bird with a 3.8 that keeps burning the module. the car is on its third, the code is random missfire and it does missfire randomly. plugs have been changed and wires re-routed, coils replaced, still same problem.
A friend told me he's found that the wires end at the connector get hard from the heat and makes the moodules fail. can this be true?
anyone else with different diagnostic/fix?
thanks,
jc
thanks,
jc
where do you get those service connectors?
Also, I have another wiring harness I can use, do I replace the whole harness or just cut and splice the connector?
thanks.
thanks.
