Injector offset
Old 12-06-2008, 03:28 PM
Peppershaker's Avatar
Default Injector offset
Trying to find a injector offset table for 30# SVO ford injectors and also pulse width settings. Have searched and can't find were any tuning files were these have been changed. I have read were this tables need to be also changed when putting in larger injectors. If any one has a file with these changes would much like to see it. thanks Bill
Old 12-17-2008, 07:06 AM
UKDriver's Avatar
When I upgraded to Accel 36lbs I had to get the offsets from the manufacturer. These are notoriously difficult to get hold of - don't know why.
Old 12-17-2008, 01:18 PM
SSpdDmon's Avatar
Try Yahoo!....seriously. That's where I found 'em. Only problem is, Ford uses a high/low offset kind of setup and the voltages don't exactly line up perfect. But, you can get close.
Old 12-17-2008, 08:10 PM
edcmat-l1's Avatar
I've never had to mess with the offset for injectors that small. Just set the IFR and that's it.
