System Too LEAN!! Need some advice
Hey guys! I just pulled The codes for bank 1 and 2 too lean and also random multiple misfire. I am trying to figure out what could be the problem as I have already sprayed the intake with brake kleen, cleaned mas airflow, triple checked all my intake rubber including pcv system and can't figure out the issue. I also am having an idle problem as it wants to hang at 1500. Mechanically the throttle body is working properly so I cant blame it. Please let me know what you think. I might just pull the intake on Thursday and replace the gaskets. I dont think the intake is cracked because it would be whistling and should have been affted by the spray unless the crack is underneath. It wont take me but an hour to pull and replace the gaskets but I am worried because the random multiple cylinder misfire code, but I do have a cam. You guys think since it's a 98 when i put the FAST intake manifold on, the system jumped out of range because the new air volume? Please help
I had the same exact issue after installing a catch can and switching to the ls6 PCV system. The code you are describing are almost always related to unmetered air entering the system. Few things you need to look for
1. make sure your PCV Valve isnt malfunctioning (thats what caused mine)
2. Make sure intake manifold gaskets are still good and not leaking. Also make sure the intake is not cracked or dammaged anywhere.
1 Post
Make sure the coolant crossover isn't holding the intake up and causing a leak. Brake clean isn't always easy to find leaks with - see if you can find a shop with a smoke machine that detects leaks...
