Need help with Predator 4.10 tuning
Re: Need help with Predator 4.10 tuning
I have the formula at home to make it work, in most cases changing the gear ratio in the Predator does nothing, you have to "trick" it by reporting a lot smaller wheel & tire size, something along the lines of 14" wheel with 50 or 60 series tire size, If no one else has this info handy I will post it when I get home this evening.
You might have to get them to make a custom tune for you. When I changed the gears out in my truck I had the same problem. Changing the tire size made my abs and brake light come on.
Larry
Larry
