how to tune for following mods with diablosport?
hey guys,
i finally got around to installing the following mods on my car which is otherwise stock:
jet hot 1 3/4 long tube headers
jet hot off road y pipe
slp loudmouth2
slp lid
k&n
I did a tune on my car when it was stock form with the diablosport. Easy plug and play and noticed a nice difference. I just don't know how to tune for the new mods. Any help before I ruin something
Thanks in advance
slp loudmouth2
slp lid
k&n
Thanks in advance
LS1Tech Sponsor
Please dont make this out to sound as if I played a bait and switch game with you, as I certainly did not.
I just went through all of my PMs with you, and you never mentioned anything about tuning for headers in those conversations.
You then come here and post a question, to which I replied with the best answer possible, see a CMR tuning dealer.
Now, thats not to say that is the only option....the Predator does have quite a bit of adjustment allowing the end user to alter the WOT A/F ratio, as well as timing and several other parameters that would help you dial in your new combo.
However, after re-reading your initial PM to me, I would STILL suggest that you let a pro tune the car on the dyno, as you clearly stated that you were not good with these types of things, and simply wanted to know if the Predator was easy to use, which it obviously was since you have had good luck with it up to now.
If you really want to take the time to learn, please join our forums and start logging your car and there are several nice guys over there that will happily help you analyze your log files to dial in your set up, though in any case it will always be BEST to tune the car on a loaded dyno or on the street with a wideband and a tuner that understands what the car is telling him.
Thanks
Mike
Thanks
Mike
so if i asked you to send me a tune for my truck in my sig you could send me one? how would i get it into the truck after that?
Mods: pacesetter lt's, custom y pipe, !cats.!air, ssra, descreened and ported maf, lid, ported throttle body.
already turned off trouble codes with diablo havent messed with a/f ratio or timing.
Mike your right. I went over my pm's and realized I assumed that it would be a breeze to do the headers (as in just tell me what parts of the menu to go to and tell the thing I put headers on lol) Obviously not the case. I take back what I said. Mike has been helpful. thanks
ricky
ricky
