98 under hood harness on a 2000 ls1
Old 01-10-2009, 10:15 PM
showstoMpinSS's Avatar
Default 98 under hood harness on a 2000 ls1
can i make a 98 under the hood harness work on a 2000 engine? also will the interior harness work? the reason im asking is bc i recently bought a 98z roller and and just piecing everthing together off of my 2000 ss, everything seems to just plug in but idk if the wiring is the same or what, and the same goes for the interior harness.
Old 01-11-2009, 10:51 AM
anyone?
Old 01-11-2009, 11:01 AM
LS1-450's Avatar
They are different. Pin outs are different. If you re-pin the PCM end of the harness & use an 02 coolant sensor, it should work.
Old 01-11-2009, 02:06 PM
not the engine harness, the harness that runs the fans, headlights, etc.
Old 01-11-2009, 02:23 PM
poconojoe's Avatar
You have a PM
