DBW TPS WOT Relearn?
Old 01-15-2009, 10:38 AM
kbracing96's Avatar
Default DBW TPS WOT Relearn?
Is there a way to reset WOT on a drive by wire tps? I have a truck that won't go to 100% throttle. Looking at the logs, some times it goes to 88% other time to 95%, depending on how hard you press on the pedal. It's a 03 Silverado. It's causing me problems with WOT kick down and shift points not being consistent. Any one know? And yes I check to make sure the floor mat was not under the pedal,
Old 01-15-2009, 11:52 AM
edcmat-l1's Avatar
Some of the ETC vehicles only go to 88%. That is WOT.
Old 01-15-2009, 02:06 PM
Jedi Master
Gh0st's Avatar
Yep, there's another PID that needs to be logged for the "proper" reading.
Quick Reply: DBW TPS WOT Relearn?
