Help w/efi live usb driver for 7.5
Once I updated my software to 7.5. I can't figure out how to make my computer take the usb driver download. My laptop won't pop a window when I plug in the V2 into my laptop.
Any help would be great. Thanks...
I'm a fan of clean install's over upgrades. You might try removing the software and re-installing. You could also send a note to support@efilive.com or post/search their forum http://forum.efilive.com
Run FTClean to remove the USB drivers and then plug your V2 back in. It will then reinstall a fresh version of the drivers.
FTClean here:
http://www.ftdichip.com/Resources/Utilities/FTClean.zip
FTClean here:
Probably had the old drivers installed still so didnt need to prompt you to change.
If you go into device manager when its plugged in does it show under usb devices?
Can you look at the licensing info on the unit from the software?
If so, then your cool dont worry about it.
If you really want new drivers just go into the device in devicemanager, assuming its showing up and click on update drivers and browse to where the new install was to pick up the new drivers.
