Help with 99-02 cluster in 98 car please!
Old 02-08-2009, 09:33 PM
fergymoto's Avatar
Question Help with 99-02 cluster in 98 car please!
Also posted in converions & hybrids.
Alright guys here's the rundown...
1998 Trans Am, formerly A4
Now: 2000 LS1/T56
2000 harness and PCM
2000 fuel tank and sending unit
Everything is wired in and working with the exception of the 99-02 instrument cluster. That is my only concern, and my only thing left to do. What specifically do I need to do to make this cluster work?
What I do know is that I do NOT need to swap to a 99+ dash harness, and that 98 uses 35 wires for the instrument cluster where as 99+ only uses 17 due to data being recieved through a serial data wire. This is the most in depth info I have been able to find after a couple hours worth of searching. Not very in depth
I suppose pinouts for the 98 and 99+ instrument clusters would help a lot. I was able to find a pinout for the 99+ but not the 98. There is one thread for 98 cluster pinout that shows up in the search but it is a dead link! I cannot for the life of me find a pinout for the 98 cluster
Can anyone here help me out? This is all I need to do and the car is DONE!
Thanks!
-Dan
Old 02-08-2009, 09:39 PM
ak95ta's Avatar
98 cluster
A1
PNK
39
Power feed from gages Fuse 9
A2
DK BLU
1936
Fuel gage signal
A3
GRY
728
SECURITY indicator lamp control
A4
BRN/WHT
419
SERVICE ENGINE SOON indicator lamp control
A5
PNK
39
A6
YEL/BLK
68
Low coolant level indicator control
A7
BRN
358
AIR BAG indicator control
A8
PPL/WHT
1572
TCS OFF indicator control (with NW9)
A10
TAN/WHT
33
BRAKE warning indicator lamp control
A11
LT GRN
11
High beam headlights on
A12
PPL/WHT
237
FASTEN SEATBELT indicator lamp control
A13
ORN
640
Power feed from PWR ACCY Fuse 7
A14
RED
225
Generator output indicator control
A15
BRN/WHT
1173
Oil level lamp signal
A16
DK BLU
1537
LOW TRAC indicator lamp control
A17
DK GRN
135
Coolant temperature sensor signal
B1
BRN
9
Odometer illumination
B2
GRY
8
IP illumination lamps feed
B3
BLK
650
Ground
B4
WHT
375
SKIP SHIFT indicator lamp control (V8 only)
B5
DK BLU/WHT
1415
Right turn signal switch output
B12
DK GRN/WHT
817
Vehicle speed signal-4000 pulses per mile
B13
WHT
121
Tachometer signal
B14
LT BLU/WHT
1414
Left turn signal switch output
B15
BLK/WHT
451
Ground
B16
TAN
31
Oil pressure indicator control
B17
LT GRN
867
ABS fail signal
Old 02-08-2009, 09:45 PM
fergymoto's Avatar
You are they man. Thank you so much.
One question, what does the 3rd number down indicate?
Example
B17
LT GRN
867<---this number means what?
ABS fail signal
Old 02-08-2009, 10:56 PM
ak95ta's Avatar
Example
B17
LT GRN
ABS fail signal
Sorry, that is the circuit number.
Quick Reply: Help with 99-02 cluster in 98 car please!
