no speedo or temp gauge
My alarm went off and my electric unlock thing is dead so i just started the car with the key and the speedo and temp gauge hasnt worked since. NEED HELP !! thanks
you may not understand me. the alarm was going off i couldn't shut it off so i stuck the key in the ignition, it started up but the temp won;t work or the speedo. its almost like its a security thing.
The key is the backup to the key FOB, to shut off the alarm. If the proper key is used to start and run the engine, that is the same as using the key FOB to turn off the alarm. Your Speedo and Temp not working has nothing to do with the alarm and how is was turned off. You have an electrical problem on your gauge cluster or sending units.
Did just the battery die on our Key fob? If it no longer works then I assume you have a much bigger wiring problem.
Above statement is correct. Key is secondary off for alarm- if you key open a locked car - you have 5 seconds to key in- I set my alarm off all the time and have to key in.
