Big Stuff 3 Issues... Help
I have a BS3 Gen 3 ECU in my GTO. The unit itself is working fine for the most part and does everything I need it to do. But I am having one very annoying problem.
When I connect my PC to the ECU without the car running it will stay connected forever and let me make changes as I please and save and update whatever I need to. The problem is that when I start the car and its running with the PC connected. About 5-8 seconds after I give the car any RPM at all it will disconnect the ECU from the PC and will not reconnect unless i turn the car off and start the process over. If the car is just idling it will stay connected for a while before disconnecting, but only like 2-3 minutes if I am lucky. I have checked all my connections and swapped the serial cable as well as the serial to USB adapter and none of this has fixed the issue.
Does anyone have any suggestions. Big Stuff is backed up like 2-3 weeks and I don't have time for that right now. I have also verified and made sure I have the most current BS3 software on my laptop. We have hooked up 4 different laptops to the car with no success!
I spoke with someone at BS3 right after I posted this. Been trying to get ahold of them all day. He is thinking it is directly related to my voltage issue which seems to have gotten worse over time. Gonna test the alternator and check my wiring and take it from there for now!
