MS2 And MAP?
MS2 And MAP?
going with a mega squirt stand alone and it has a built in MAP sensor. now should i also upgrade my stock MAP sensor as well? or would staying with stock be fine becuse MS2 will be running the motor
If your running the stock 94 computer, I don't think you can put a 2 bar map in it with out a LOT of work cutting all the map tables in half for the 2 bar since there is nothing like the custom os's the new pcm tuning suites have. Since the stock computer will be pretty much just running the tranny, and timing I would just leave it alone.
its a MS2/ stock computer hybrind. MS2 takes care of running the motor, well the stock comptuer looks after the ABS AC and all that
the MS2 has a built in MAP sensor, but i wasent sure if the stock computer that will be looking after every thing els should be able to see the boost as well
