Diablo Tune (this is gonna sound crazy)
I turned my car the other day with my Diablo Tuner. I went with the canned tune and didn't modify any of it's parameters. I really couldn't tell much difference in the car even after about 100 miles and I haven't driven it far enough to check gas mileage yet.
Well when I was changing headlights the other day I had the battery disconnected overnight. Once I put it all back together it ran like crap for a little bit until it re-learned everything. I have about 50 miles on it since then and the car seems to run a lot better. Is it possible the tune didn't really kick in until I disconnected the battery? I know it sounds crazy and the answer should be no but I swear it feels waaaaay different.....wtf?
Before huh? This is interesting to me. I really dont understand quite exactly what takes place by doing this. And I'm curious as to whether it should be done before or after the tune and why either one would make a difference?
Like said, I know the tune is the same but the car sure does act different now.
LS1Tech Sponsor
and the "adaptives" being your fuel trims, amount of air flow via the MAF sensor, etc etc...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
in simple terms from what I understand its wiping its memory clean of the old fuel trims so it can relearn the new trims from scrach which in most case is faster then just adjusting to the new setup
That all makes sense. I would highly recommend that this be required as 1 of the programming steps. Before I wasn't all that impressed with the product because I didnt see an immediate change. I just tossed this mod into the "every little bit helps" category.
I think doing this would give your customers the instant gratification we are all looking for when we modify something.
