98 & 99-02 pcm
98 & 99-02 pcm
Are the 98 PCM's different from the 99-02, if so will the 98 PCM work with a 6.0 Block out of an 2006 GTO? The 6.0 Has the 24X Reluctor Wheel and I bought the Cam/Knock Sensor Extension Harness Already but Im still having problems just wondering what it could be. Any Ideas?
Flash-Based Factory PCMs
Are you using the LS2 cam gear?
Yes I have the LS2 Cam Gear. My problem was the I had the 7.500 length pushrods from Trick Flow and when I tightened them down to 22 ft.lbs ALL my valves were staying open and it had no compression what-so-ever. I got the stock length 7.400 pushrods and shes goin good now. Thanks Guys
