Autotap Log Help (NoGo)
Re: Autotap Log Help (NoGo)
I got the filies hosted thanks to JP. Here is a link to the two in reference. Any help would be greatly appreciated.
Autotap Logs
Autotap Logs
what is it you need help for with them? I only looked at the cruise & WOT one (filtered by fuel cell 22 tps =99.6) but didn't see anything outta the ordinary... little to no knock, ltrims almost always 0 at WOT (99.6 throttle)
O2s look good (few at end that look a little lean, but RPM is low so negligable i'd think)
Timing seems a little low to me... but that may just be how the 02s are or is this a custom tune? (lower timing for spray) ? (i'm guessing this is an M6? timing looks really low at end, 12, 13 degrees but RPMs are really low too so was this a 4th gear cruising and hit the gas run at the end?)
No, the cruise & WOT was done in 2nd gear for WOT purposes. Yea, this is a custom tune. What I was wondering about was during cruise, I am almost always in FTC 4. Also during some cruise, my FTC is 22. Just trying to get a better grasp of this.
