98 to 2002 repinning C21 C220 C230 Help?
Hello,
Finished installing 2002 engine ,trans and pcm into 98 T/A and have the pinouts for the 98 and repinning to the 99 &up pinout C 210 went easy swapped circut for curcut into correct location now onto C230 and running into a few problems first the C210 Connector end are female and need to be male to use into C230 anybody have a source for pins? 2nd problem C230 pin A is circut 474 and there is no circut 474 on 98 harness this circut is Reference voltage feed 5 volt there is a 5 volt reference feed on 98 harness it is circut 598 can I use this circut?? Problem Number 3 Fuel sensor signal circut is 1589 on the 2000 pinout and on the 98 there are 2 fuel gauge sensor signals but neither is circut 1589 my choice is circut 1936 or circut 30. Problem 4 C 230 slot K shows circut 1049 as PCM serial data signal class 2 there is serial data signal on the 98 harness and finally last thing there is a white wire circut 121 tach on the 98 and it shows nowhere on the 2002 pinout for the tach wire do I have to run this wire out to the 121 curcut on the inner fender connector 105 I think it is?
Sorry lots of questions just trying to figure out my last few problems on this swap any and all help would be appricated!!! Thanks Paul
