converter locking in 2nd & 3rd @ WOT...EFILive
11 Second Truck Club
we have set everything we can think of to keep it from locking...with NO luck!
ONLY way we can keep it from locking is thru the scanning software...manually overriding the solenoid...
locks and unlocks just fine when daily driving...
this started happening after the new, higher stall converter was installed...
any thoughts?
something we may be missing?
thanks in advance!
any thoughts?
thanks in advance!
well...maybe not the release set to the same as apply, but...
it worked fine until the new converter was installed...
Oh, I'm sorry, I didn't see "@ WOT" in the OP's post, my mistake (slap me now)...
what I said has to do with PT only, so please disregard it.
When you log TCCMODE, TCCDC, TCCSLIP, can you determine that the PCM is commanding it locked during WOT...?
Can you post some logs...?
The only thing that changed is the converter...?
CURRENT GEAR is shown as well...
attached is a log of the first run of the day last Saturday...
we had made some changes and I ran it to see if it was still locking @ WOT...and it was...
the rest of the day I had to override it using the scanning software...
disregard a/f...it had been mistakenly set to show commanded instead of actual...and yes...I was lean all day
9-Second Club
Yep, WOT TCC lock and release tables, you evidently don't have access to. GM stopped using them in 2001. Since 1987 GM has locked the TCC @ WOT, most 700R4 and 4L60E trucks locked WOT @ 75 MPH in 3rd & 4th.
The 4L80E trucks all lock @ WOT in 2nd gear also. If you have a straight binary copy of your file, email it to me and I'll fix it for you. Since you use EFILive, I kinda doubt you do.
well...I started thinking about that...
other than WOT tuning sessions on the street the first three track days after installing the 4L80e resulted in either water pump pulley being snatched off (twice), the P1SC taking a dump, or repeatedly hitting the rev limiter on both the 1-2 and 2-3...so...having said that...we probably wouldn't have known whether it was locking or not...I know for a fact that we weren't logging it...
the TCC in the first converter that I was running w/ the 4L80e went South shortly after that and I ordered the new converter...
We only started logging TCC MODE after the TCC went out on the first one...this info learned today may very well be the reason why though...
as far as I know...the 4L60e NEVER had this issue...
just spoke w/ cablebandit and he said that he can change those same tables said to be PT only and is able to lock and unlock his...and he is SD...
I'm totally confused now...
9-Second Club
Maybe I added that to my TC definition files, I have added a lot of things to my TC definition files that no software you buy gives you access to. I'll have to look at a "stock" definition file to know for sure. If not, I'll forward the table locations to TC so it will be included.
But the cals most certainly do have WOT TCC tables, until 2001. 2001 and later do not. 1999 & 2000 4.8, 5.3 & 6.0L trucks, with the LS1 style boxes do.
