Water Temperature Sensor Bad?
Old 02-26-2009, 04:47 PM
QuickdomesticRacer's Avatar
Default Water Temperature Sensor Bad?
I am trying to figure out my random and catalytic damage misfires are coming from.
It is super bad at cold, until it gets up to operating temp (180*). Then depending on weather outside(warmer the better), It either goes away completely, or still is there.
I replaced the o2 sensors. Brand New Flow Matched/Tested Injectors. 1 year old MSD 8.8MM Wires, 6 month old NGK TR6 plugs.
If the computer pickup for water temperature is incorrect, could it throw it off, and pull timing/add fuel/etc to cause this issue?
I have milled heads w/ a cam. 11.7:1 compression Ratio.
2 years no problems like this prior.
Recently Tuned in an attempt to fix problem. I have perfect A/F Ratio ~13.X.
Old 02-26-2009, 06:53 PM
5_02ls1's Avatar
my coolant sensor went bad and when datalogging it would show -39 degrees and run so rich the car would flood out.....
Old 02-26-2009, 10:55 PM
I see. And this is the one that is on the driverside cylinder head behind the power steering pump?
Mine still registers in the dash, did yours when it went bad?
Old 02-27-2009, 10:14 AM
Moderator
jimmyblue's Avatar
ECT sensor, or its connector, will whack the
operation big time if it's dead or simply flakey.
It could get better with just a pull & reseat of
the connector. Maybe inspect both for crust,
loose or pushed-back pins, etc.
Old 02-27-2009, 10:42 AM
slow's Avatar
A friend just had this happen on a 98 z28, the dash read fine, but the datalog was -3x degrees, causing all kinds of problems.
Try a datalogger to see what the pcm thinks the ECT is.
Ryan
Old 02-27-2009, 09:03 PM
5_02ls1's Avatar
no mine stopped....the 98 uses a 3 pole sensor....one wire comes from pcm,one wire is a return signal to the pcm,and the last wire operates the gauge.....do you have an ses light on.....
Old 02-27-2009, 11:36 PM
Yes, For Random Misfires.
And thanks for the input Jimmy and Slow.
If I wanted to check the 3-wire connector w/ a DMM, what would I need to do?
Old 03-05-2009, 11:12 PM
Bump. Replaced the ECT. No avail. Pulling and checking plugs on Sunday.
What about the IAT?
Old 03-05-2009, 11:42 PM
Joshiedoom's Avatar
IAT is 12 bucks at autozone.
I replaced mine because I felt the k and n oil messed it up. I got a much better idle quality with the new one.
Old 03-06-2009, 08:47 AM
Its annoying just throwing parts at the car. So plugs and IAT are next. Thanks for tips. Any other suggestions?
Old 03-10-2009, 12:14 AM
Changed plugs/IAT.
The code changed to P0353 and P0327(KS B.1 Low Input) Both KS are brand new and harness is also. Had the same issue ever since I replaced them the first time(no codes, but tuner said they didnt appear to be workin well, so I replaced them). Installed properly, and checked continuity in wire).
P0353 is Primary/Secondary IGN Coil Malfunction (C = #3). So is Cylinder #3's coil bad or wiring harness or something?
