ls1edit and "drive be wire" question
Old 10-15-2003, 05:07 PM
single digit dreamer
parish8's Avatar
Default ls1edit and "drive be wire" question
i am waiting for the offical 03 truck ls1edit version to come out but in the mean time can anyone answer this?
got an 03 truck with a 4.8 and auto, only mod so far is a 100shot, at the 1-2 shift i see the usual 30deg reduction in timing from TM but i also see the throttle actualy close to 40% , cant be good spraying at a closed throttle plate. are there any charts to control this part of TM seperately? will it stop closing if i fix all the TM tables? right now i dont mind the timing reduction since i have a stock tranny but that closing TB has to stop, it sounds like a stick when it shifts.
Old 10-15-2003, 10:42 PM
blownerator
BlownChevy's Avatar
Default Re: ls1edit and "drive be wire" question
I belive there is a table for the DBW in edit. I will look, maybe I can find out for you!
