Injector offset w/svo's whos done it, interesting results?
I ve been messing around at the track and I come to find out that when I scale the ifr table for the svos and make a pass the car is sluggish on the top end. Next I changed back to a previous file of edit for stock injectors and the car sees a 4 mph increase in the quarter. I have both edit files tuned by driving around to adjust ltrims then adjusted wide open throttle through pe vs rpms. Also there is slight changes to the ve table up top, about a 1% change, but other than the ifr tables they are the same files. The funny thing is that the car is faster with stock injectors that are at about a 95% duty cycle???? Im really beginning to believe this is an offset porblem.
Re: Injector offset w/svo's whos done it, interesting results?
I posted injector offset either last week or earlier this week, for a few different injectors in the pcm forum.
Gary
Gary
