Is the AEM wideband any good?
Old 03-30-2009, 08:44 PM
2002CAMAROSSLS1T56's Avatar
Default Is the AEM wideband any good?
Seems like a good price. It's not a **** pile like Innovates LM-1 is it?
Old 03-30-2009, 08:45 PM
Forgot the link. here it is.
Old 03-30-2009, 09:00 PM
Ls1Gummi's Avatar
I have one. I'll tell you this i took my car to get it tuned and it read basically the same as what the dyno a/f reading did.
Old 03-30-2009, 09:32 PM
Cool, so if I go order one, then everyone comes on and tells me they're garbage?
Or would it be safe to order now you think?
Old 03-31-2009, 08:30 AM
slow's Avatar
I've compared mine to an AFM1000 and A1000 widebands (both good NTK based units) with good results.
Ryan
Old 03-31-2009, 01:27 PM
Restricted User
2001 Pewter WS6's Avatar
I have one and it works great. Very easy to install. I had a LM-1 and was a nightmare...
Old 03-31-2009, 05:43 PM
crf538's Avatar
happy with mine
Old 03-31-2009, 06:56 PM
BOTTLE ROCKET's Avatar
I just installed one (good price) but haven't had enough time to evaluate it yet
Old 03-31-2009, 07:04 PM
Is the 0 to 5volt analog output the one used to connect to the extra wire in your AC pressure plug to tap into hp tuners and get the wideband reading on your scan?
Old 04-01-2009, 11:06 AM
PewterMNZ's Avatar
what did you guys hook up to for the power and ground?
Old 04-01-2009, 09:01 PM
I'm going to wire it like my Oil, Water, and Trans temp gauges.
I snaked a wire from under the steering column and into the fuse panel. There are female plugs labeled ACC, just double check with a volt meter or test light to make sure they come on with key on only.
Then for ground attach the wire to metal under the panel thats by your knees when you're sitting in the car. Take that panel off, find a good solid bracket.
Old 04-02-2009, 10:58 PM
BuckaroooZ28's Avatar
i luv mine, dead on
Old 04-03-2009, 08:01 AM
I ordered the kit.
Over the weekend I'm going to pull out a header and see if I can weld in this spare bung I have here. Going to see if it'll fit somewhere between 10 and 2 o'clock.
This way the dirty work will be done when the kit gets here.
Old 04-03-2009, 08:11 PM
Originally Posted by 2002CAMAROSSLS1T56
I ordered the kit.
Actually I pulled the pass side header today and welded it in.
Hope it's a good angle.
Quick Reply: Is the AEM wideband any good?
