98 pcm
Old 04-05-2009, 10:39 AM
ajw2500hd's Avatar
Default 98 pcm
I have a 98 camaro ls1 m6. Do i need to change my pcm to a 99 or newer if i want to tune for cam or build motor etc.?!?!?! Thanks aj
Old 04-06-2009, 06:08 PM
Former Vendor - No longer Vendor
ArchetypeZ28's Avatar
You don't have to but we would highly suggest that you do so. We did a bit of a write up on this a long time ago.
http://www.efialchemy.com/db/02to97pcm/02to97PCM.html
Old 04-06-2009, 07:28 PM
LS1-450's Avatar
The 99+ is definately a better choice. However, I have not had any issues using a 98 PCM to control my H/C LS6.
98 PCM uses the back-up VE table for AutoVE. The back-up table columns are scaled every 10 KPa MAP. So, you have to fill in the 5 KPa columns on the Main VE table by estimating the value between columns. PE fueling has not been an issue.
Old 04-06-2009, 11:22 PM
JonCR96Z's Avatar
99 and 00 also have secondary VE, but they can be updated with a new OS.
For a radical setup or forced induction. Definitely go with a newer PCM. You'll be OK with heads and cam though.
Old 04-07-2009, 07:54 AM
2manytoys's Avatar
I asked the same question before purchasing my car. Most people said I would not have any problems with tuning the 98 PCM. I do know that there are some restrictions to the 98's but I think that is for FI setups.
Old 04-07-2009, 09:53 AM
slow's Avatar
IF I had a 98 corvette, I would switch regardless. On my 98 f-car, I switched, and then switched back, since I did not like the wiring harness mess with the pinout arrangement.
Ryan
