EFILive V1 vs. V2
The V1 is a great deal if you only plan on tuning pre-06 vehicles. Even though it does have black box data logging; it's very limited compared to the V2 version. The V2 BB is much better and uses a SD card for memory. Hopefully soon they will have the Black Box flash tool available soon. If you want to tune 06-up vehicles you have to buy V2.
I'm a Vette guy and can't see investing in a C6 in near future. Too much $$$ to risk wrecking at the track. I got my Z06 for 15k and can walk away from that.
I'm a computer geek anyway so I would rather download to notebook rather then using a BB. 20 minutes for a session should be just fine.
So far from any of the forums I've looked into, the only drawback on the V1 is only having two inputs instead of 4 to pull data into the software.
I would bet that in a year or two the small 8 inch netbooks will have touch screens too. Save your money and get V1, install it on a small netbook, and wait for technology (touchscreens on netbooks) to catch up making the V1 practically the same as the V2.
I have both... I like how V1 is much more compact compared to V2.
V2 has more features than V1:
- reads serial AFR from most popular widebands;
- 4x 5V analog inputs instead of just 2;
- two thermocouple inputs;
- two 2-state 12V switch inputs;
- black box logs (BBL) can be stored on SD memory cards so they can be huge;
- black box flashing (BBF) will be coming soon (still in progress, but don't buy just yet because of this);
- LCD display shows logged pids and other information;
- audible alarms (e.g. you can set thresholds on pids like ECT and KR, and when exceeded the audible beeper/buzzer sounds); and you can set certain LEDs to come on also;
- BBL mode can capture all the OBD-II information (e.g. DTC's and Mode $06);
- Displays English descriptions of DTC's;
- Covers CAN bus and ECM/TCM modules (later year/model vehicles).
V1 is:
- cheaper,
- simpler (has only one button: Start/Stop),
- smaller, easier to lug around,
- captures upto 23 minutes of logged data (short logs means easier/quicker viewing).
V1 is certainly more than adequate for the LS1/LS6 PCM.
As far as analog inputs go, you'll probably use 1 or 2 at most.
V1 is:
- cheaper,
The developers have been and/or are working on this... but I do not know when it will be ready.
