HP Tuners Noob....ecu questions
I'll try to make this as short (and hopefully to-the-point) as possible. I'm really pretty-much lost right now.
Here's what I have:
1996 Firebird....swapping to a Turbo 5.3 using 2000 Firebird harnesses and 2000 truck ecu......4l80e conversion is being put together as well.
Here's where I need to be:
ECU reading correct vin# and vehicle information (ie Firebird, as opposed to truck) when the local DEQ hooks up to scan for emissions....as well as 4l80e shift tables....and real-time tuning ability. Lastly, I need to make all this happen using as few HPTuner Credits as possible. WHew!! I know it might sound like a lot to ask, but I'm needing to know the best way to make all of this happen.....even if it means sending the ECU out somewhere to have the mods done.
Thanks for any help!
Here's what I have:
If that's the case, I suppose that the DEQ would just treat the car as if it had simply had a defective ecu replaced. So, as far as everything else that I need to have done....what are my best options?
According to my local GM dealership, GM does not "support" this kind of mod any more (too many wasted ecms), and hence are not equipped to do it....so no dice there. I can provide a valid vin # for a 2000 auto-trans Firebird (I work for a dismantling facility), but would need to have the 4l80e parameters added in.....not sure how to go about this now. Oddly enough, finding a true 2000 firebird ecu seems to be a bit difficult.
