99 LS1 Engine/PCM/Wiring Harness in a 1998 Z28?
Would it be plug n play if I got a 99 Z28 pullout that includes wiring harness and PCM and plugged it into my 98 dash harness? Or would this not work because I know some things did exist in the 98s that dont in the 99s and vice versa, just wondering what would be neccesary to install it.
I just swaped a 99 ls1 engine/harness in a 1998 trans am. Only difference from me was the car was a m6 and i was swapping a auto in it. The acc/inside harness should be the same. I did a pinout on the interior harness to the engine/fuse harness... Every pin was the same.
You should be able to use the engine harness and pcm and be ok.
Goodluck
Goodluck
Those arent the pinouts im looking for, I mean the pinouts for the connectors to the dash, I heard that the oil level sensor is the only diff. 2 connectors in dash instead of 3.
Well the coolant temp sensor is different only because the 99+ sensors are fake, they only show an overheating condition, 98 is the only yr that worked so you may wanna try to wire up the 98 coolant sensor instead. The one that talks to the pcm does work though, the gauge is the incorrect part. There are tons of different pieces to be rewired so im going with the 98 wiring and then Im going to try and wire up my 99 off the car so itll be ready for plug n play.
dam i finally found someone in the same problem as me.......ok i have 98 engine harness and pcm and plugged it to a 99 dash and doesnt work at all dash blinks no gauges work battery doesnt stay charged. So did you fix your problem yet let me know.
