How much tm is decreased in the predator tune?
Old 04-10-2009, 10:46 PM
oddwraith's Avatar
Default How much tm is decreased in the predator tune?
Hey just wondering if anyone could tell me how much of the torque management is removed in the canned tune that comes with the predator handheld. Also is there any way to adjust that one aspect of the performance tune without having to create a whole new custom tune or modify the stock one. I'd like to use the predator performance tune but be able to adjust some of the individual parameters within it. Thanks.
Old 04-10-2009, 11:04 PM
boola1341's Avatar
I don't know how much tm is removed but I was told to turn off the first two options and leave the 3rd option on if you have the stock trans. After you install the predator tune you can still adjust whichever parameters you want. I got a lot of info from there website.
Old 04-11-2009, 05:17 PM
LS1Tech Sponsor
Mike@Diablosport's Avatar
Current versions of the GM gas Predators have a good % of the TM removed, I'd have to ask one of our tuners on Monday exactly how much.
We do not disable the TM Upshift abuse mode in the A4 vehicles. We do let you disable that in the adustable parameters, so you could install the performance tune and disable the TM at the same time, in addition to the ability to adjust any of the other parameters.
Thanks
Mike
Old 04-11-2009, 08:25 PM
oddwraith's Avatar
Thanks
Mike
Okay that's great to know. Thanks again Mike, you've been helpful more than once.
Old 04-15-2009, 10:56 AM
oddwraith's Avatar
Thanks
Mike
Hey Mike, did you ever find out how much TM is reduced on the canned tune? I have the slp version so I don't know how much difference that makes. I'm finding the 1-2 shift a little hard and I'm not sure what to attribute that to? Any ideas?
Old 04-15-2009, 01:13 PM
LS1Tech Sponsor
Ahhhah...we don't write the SLP tunes, so I cant say for sure, but if you upload a copy of the current tune from your Predator and email it to me, I can take a look....
Old 04-15-2009, 11:37 PM
oddwraith's Avatar
Well I can't upload yet since I don't have the connection for it yet. All tapped out money wise at the moment lol. But I am going to go into the tune myself and turn TM back on. That way I know I'm ok as far as that goes. Thanks.
Old 04-16-2009, 11:28 PM
oddwraith's Avatar
If you have TM disabled does it have an increased wear and tear effect on the driveline even during normal daily driving conditions? Or simply when you get on it?
Old 04-17-2009, 07:28 AM
LS1Tech Sponsor
Yeah, really only if you are getting on it...
Old 04-17-2009, 09:03 AM
Moderator
jimmyblue's Avatar
It's the "tear" you have to worry about.
On my original-version Predator it was all-or-nothing
(either all off, or stock). Ans occasionally it would
"forget" to turn it off though the next time it'd
"stick".
If you increase the shift speed, you won't hardly
notice the TM "bog". It's the combination of slow
soft shift, and dead timing, that aggravates people.
Punking the motor protects the trans, the trans
is known weak, so if you have to choose between
all and nothing, I'd stick with "all". It makes very
little difference to ET / performance (especially if
shifts are set crisp).
Old 04-17-2009, 10:51 AM
oddwraith's Avatar
Very good info thanks for that.
