megasqeuir boot control cant keep pressure?
Old 04-23-2009, 11:52 AM
miguelcg3's Avatar
Default megasqeuir boot control cant keep pressure?
Hi everyone
I have megasquirt ( msnspark) set at 9 psi, from my logs the wastegate opens at 9, but then pressure goes as low as 6.5 or 6 when I shift it happends the same.
Is a turrbonetics wastegate.. I dont remember is the cheaper one , I think 38 mm.
my setting are:
PWM 19.5 hz
proportional 49.8
diferential 9.9
increase voltaje= increase boost
right know the wastegate has a 9 psi spring, and did the same thing just hooked without controller... Im just using the lower port from the wastegate.. should I use both of them??
thanks for your help beforehand
