richen up part throttle???
so I have tuning...but I'm pretty sure our part throttle tuning is fixed at 14.7:1....
right????
so is there any way to richen up the part throttle??? get it a little closer to 13.3:1 or so???
I know it reads the o2's at part throttle and ignores them at WOT...
so can we put in some kind of resistor?? or is there a way in Ls1 Edit to take care of it....
right????
If I was worried about burning gas...I wouldnt have bought this car and done what I have done....
I'm just thinking on the driving around town Idea...If we racec at 13ish A/f for best power...and I wasn best power all tha time..not just when I stomp on it....why wouldnt it make sense to richen it up a little...maybe not as rich as WOT...but definately a little....and when you let off...you wouldn't get such a big dip in the A/f....it would stay more consistent....and you would have less dangerous lean spikes on the street...have you ever seen an a/f printout from a wideband on the street???
not good when you let off tha gas.......many times it goes dangerously lean because it cant correct fast enough and it overshoots 14.7:1 ....
Yeah I've seen it, I have a wideband. I don't think those lean spikes mater since the throttle is closed and the injector pulse width is very narrow when it happens. But if you really want to mess with this, I sugest you use the VE tables to do it. VE in the LS1 seems to play into the transient throttle response.
I would think plug fouling might become an issue with a constantly rich mixture.
I would think part throttle responsiveness, power, and MPG would be LESS with a mixture much richer than 14.7:1.
If you need more power at part throttle, I'd suggest using more throttle.
Originally Posted by Colonel
...But, I'd curious to see what would happen if you changed the "Stoich Ratio" in the fuel tab to a value less than 14.73684210.
Of course if burning gas isn't a problem, why not unplug the MAF and tune the MVE table for AFRs other than 14.7:1?
Richard
