torque management
Old 04-24-2009, 08:45 PM
formula4437's Avatar
Default torque management
i think this is the problem just looking to see if i am correct.
the car shifts normal while cruzin around but if i do a wot run it seems to bog down after 2nd gear shift to 4500 rpm and very slowly climbs out of it unless i let of the gas.
Old 04-24-2009, 08:52 PM
b.lee's Avatar
With all that stuff done to the car, quite possible.
Mine is reduced by 50%-75% or so... had a nice friend of mine do it with EFI Live
Old 04-25-2009, 02:38 PM
oddwraith's Avatar
I'm not sure if you mean that happens after disabling TM or while leaving it on. I'm running the standard slp diablo tune which I believe has a fair amount of the TM removed. I find it does get rid of that little bit of lag that I had. But then again your are running a totally different and more powerful setup than myself. Are you running the stock 4l60e on that?
Old 04-25-2009, 05:30 PM
ya stock 4l60e with a b&m shift kit and tci 3500 converter
Old 04-26-2009, 08:49 PM
anyone else
Old 04-27-2009, 09:07 AM
Moderator
jimmyblue's Avatar
Torque management only persists for the duration
of the shift (or actually a bit less). A bog that takes
a long time to go away, is more likely a knock retard
event. Have you been scanning?
Old 04-27-2009, 11:27 AM
no dont have a scanner but am taking it to my tuner on wednesday
Old 04-29-2009, 05:40 PM
went to the tuner today, it turned be the tps due to the fact i ground down the throttle stop to far so when i was at full throttle it was past the point where the tps could read it
Old 04-29-2009, 05:50 PM
b.lee's Avatar
So it runs out nicely now?
What tracks do you race at?
