MAF to SD tune, using HP tuners, what do i need to change?
I read through the FAQ and didnt see anything bout this, so i thought i would ask.
first my setup:
96 240sx with a 408 LQ9 / t-56
ecu is from a LS1 auto, that has been reflashed.
currently making 416hp/449tq on a pump gas tune using HP tuners
I am looking to switch over to a speed density tune and add some n2o
other then buying the 2 credits (also going RTP) and unplugging he MAF, can someone tell me what else has to be done?
i looked the HP tuners site, but it is kind of confusing
thanks in advance for the help.
kelly
first my setup:
kelly
You don't need one for SD alone but you will for RTT. Technically all you need to do is unplug the MAF to get into SD mode, but to do a proper tune you need to copy your high octane timing table to your low octane table, and tune the VE table.
i want the 1 bar SD.
Pay for the RTT SD 1 bar and start tuning?
im not worried about the actual tuning, the guy that tunes my car knows all that
