LS1Edit & subsequent log info - AFR
My H/C car recently failed NY inspection. I logged the car and found my Ltrims were slightly high (+12) after the motor work.
I recently tuned the car using LS1Edit.
Question: If I immediatly log the car again will I get accurate LTrim readings or should I wait until all the PCM diagnostic test are run again before I take another log reading? If yes, how long does this usually take?
Thanks...
Thanks...
