Anyone have a MAF Table for a 03 Z06
Old 10-31-2003, 08:43 PM
MNC5's Avatar
Default Anyone have a MAF Table for a 03 Z06
I've got an 02 MAF Table and need an 03 ZO6 Table for Reference.
Thanks
Old 10-31-2003, 11:35 PM
Bink's Avatar
Thanks
Here you go:
2003 Z06 Hz
750 800 850 900 950 1000 1050 1100 1150 1200 1250 1300 1350 1400 1450 1500 1625 1750 1875 2000 2125 2250 2375 2500 2625 2750 2875 3000 3125 3250 3375 3500 3625 3750 3875 4000 4125 4250 4375 4500 4625 4750 4875 5000 5125 5250 5375 5500 5625 5750 5875 6000 6125 6250 6375 6500 6625 6750 6875 7000 7125 7250 7375 7500 7625 7750 7875 8000 8125 8250 8375 8500 8625 8750 8875 9000 9125 9250 9375 9500 9625 9750 9875 10000 10125 10250 10375 10500 10625 10750 10875 11000 11125 11250 11375 11500 11625 11750 11875 12000
LS6 Gm/s
* 0.39 0.41 0.44 0.46 0.48 0.5 0.52
* 0.54 0.56 0.58 0.6 0.62 0.64 0.66
* 0.68 1.42 1.76 2.1 2.48 2.86 3.26
* 3.7 4.18 4.71 5.31 5.97 6.68 7.43
* 8.23 9.08 9.97 10.91 11.93 13.05 14.27 *15.59 16.98 18.47 20.05 21.72 23.48 25.34 *27.28 29.34 31.48 33.74 36.11 38.62 41.3 *44.17 47.2 50.4 53.77 57.3 61.01 64.88 *68.91 73.12 77.47 81.97 86.63 91.45 96.43 *101.59 106.9 112.36 118.01 123.83 129.84 136.05 *142.48 149.13 155.98 163.06 170.38 177.92 185.7 *193.73 201.99 210.52 219.3 228.34 237.64 247.23 *257.06 267.16 277.56 288.25 299.25 310.55 322.2 *334.16 346.49 359.16 372.22 385.66 399.51 413.77 *428.45 443.6
joel
Old 11-01-2003, 05:58 PM
MNC5's Avatar
Originally Posted by binksz06
Here you go:
2003 Z06 Hz
Joel
Thanks. I ditched my MAFT and tuned the truck w/o it. It runs better and pulls smoothly even after exceeding the limits of the MAF. There doesn't appear to be to much difference between that and the stock table that came with my 03 Silverado.
Thanks Again
Old 11-10-2003, 07:22 PM
spanktu's Avatar
if gutting a stock truck maf (85mm)
this is actually the table you should put into edit correct?
Old 11-10-2003, 08:38 PM
MNC5's Avatar
I'd make a comparision first depending on the year of your truck. But to answer your question yes. The difference is slight
